is it enough?(sprocket bolts)
Old May 25, 2005 | 05:21 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default is it enough?(sprocket bolts)
The nuts that hold on the back sprocket... i didn't put the lock things on bcause i bent them to hell so will lock tight and tightening them REALLY TIGHT be enoguh to hold them on?
Old May 25, 2005 | 06:55 PM
NBake's Avatar
if its red loctite then itll hold anything on
Old May 25, 2005 | 06:58 PM
Speedy2222's Avatar
blue?
Old May 25, 2005 | 07:03 PM
Speedy2222's Avatar
what about chopper based lock tites?
Old May 25, 2005 | 07:04 PM
NBake's Avatar
blue should work. red and blue are for heated areas and green is just for non heated like bolts that hold the plastic down, so blue should work fine. let it dry good and check it for the first 100' of riding jus to make sure tho
Old May 25, 2005 | 07:05 PM
Speedy2222's Avatar
i will test ride it and check the bolts to make sure...
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
