Raptor...Axle install?
Old May 25, 2005 | 10:36 PM
lottery's Avatar
Default Raptor...Axle install?
Ok, this one is for the mechanical GURUS.. My new Gforce axle will be here next week and I have a couple of questions on the install...
First... How hard is it to take off old axle and put on new one?
Second... Do I need any special tools?
Third ... Do I need a repair manual?
Fourth... How long should this take?
P.S. Any tricks of the trade to make it go smooth? By the way I rate my mechanical ability just a little better then I can ride... a little above novice... Thanks
Old May 27, 2005 | 06:22 PM
TexasRaptor's Avatar
Get a Clymer shop manual. It'll cost about $15 or so.
If you can read, this manual will walk you through anything you want to do to your quad. It has good pics and very detailed directions on how to dis-assemble and re-assemble sections of the qaud. It even has a great electrical section.
Good luck!
P.S. If you can change the oil in your auto, you can do the axel change with no problem. Just take your time and invest in the Clymer manual.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
