welding frame please reply
Old May 25, 2005 | 10:47 PM
UltimateAussie's Avatar
Default welding frame please reply
the frame on my yamaha three wheeler just snapped and i was going to get it welded at the local welding shop but i didnt know if it was worth it to have it welded becuase i wasent sure if they can be welded and still have sufficient strength.. another problem is the trike has no suspension. so if the weld will be stroge enough i will get that done if not i will part it out on ebay
thanks
Old May 25, 2005 | 11:02 PM
BONEshock's Avatar
depends on where it broke, how good the welder is, and if you can brace it or span a piece of metal across it to strenthen it up. I welded a rancher frame once and its was just like new, but it was also on the A arm bracket.
Old May 25, 2005 | 11:25 PM
slick500's Avatar
If the tubing is not rusted out it should work fine. May want to gusset it a little since there is no suspension, will give a little added strength. Good luck hope it works out for ya'...
Old May 25, 2005 | 11:37 PM
caliraptor's Avatar
I had some welding done on my raptor's frame. A weld broke so I had it repaired and its been holding up just fine. If you get a competent welder, you should be fine
Old May 25, 2005 | 11:41 PM
cool thanks for the replies im going to get it welded this weekend i think
Old May 26, 2005 | 03:00 AM
LikeitsStolen's Avatar
If you find a good welder you should be fine. Technically a weld should be stronger than the material your welding if done right.
Sorry, didn't tell you anything new, just thought I'd post ***** a little and throw in my 2 cents.
Old May 26, 2005 | 08:11 PM
thanks again for all the responses. school just ended for a four day memorial weekend and i am going to take it to the welder soon
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
