22" rear tires - impact on bearings
Old May 26, 2005 | 02:13 PM
RiverzEnd's Avatar
Default 22" rear tires - impact on bearings
Someone said to me the other day "those big bear klaws may be messing up your bearings". I didn't know how to answer this. They are heavy as heck though with the ITP steel rims. Should I be concerned about the lifespan of my bearings with these tires? I haven't heard of this before. Thanks.
Old May 26, 2005 | 05:05 PM
TooFast2Pass's Avatar
So, I'm assuming you're running those big tires on your Raptor. Yes, it is likely that those tires will create premature wear on your bearings not only on the axle but the swingarm bearings, shock bearings, etc. I'm comparing this to say the same Raptor with 20" rears. The bigger concern is your clutch. Those heavy wheels and tires are really putting a huge load on that stock clutch. Chances are that the clutch will wear long before the bearings give you trouble.
Old May 26, 2005 | 05:42 PM
RiverzEnd's Avatar
That's good to know. Thanks. I knew the clutch would be a problem so I dropped a tooth in the front sprocket to bring it closer to stock gearing.
Ean
Dec 19, 2022 08:48 AM
RedRancher
Oct 15, 2020 01:45 PM
rcappie4
Jul 18, 2015 07:51 AM
Peter_
Jul 18, 2015 07:06 AM
rcappie4
Jul 10, 2015 04:54 PM
