Bayou electric start question??
Old May 27, 2005 | 06:45 PM
02skidoo's Avatar
Default Bayou electric start question??
OK, If I leave my bayou sit for more then a week or so I can try the electric start till the battery goes dead and it wont start, BUT on the first try of the pull rope it fires right up. Now if I start it every few days it starts fine with electric. I would think if I had a fuel problem it wouldnt start with the pull rope either. Anybody have any ideas? It starts perfect when it does, cranks about 1 second and up and running, the pull start always starts it.
Old May 28, 2005 | 01:30 AM
hondabuster's Avatar
Id say the battery is failing.
If you hook up a voltmeter, to the battery, and watch the voltage while cranking...ill bet it drops below 10 volts. But if you run it every day, then it keeps enough of a charge to get spark.
If you dont have a voltmeter, you can take the battery in to a auto parts store and get the battery load tested, this will verify if its good or not.
Old May 28, 2005 | 11:15 PM
UltimateAussie's Avatar
i think hondabusters gtot it on the head
Old May 29, 2005 | 12:41 AM
02skidoo's Avatar
well, certainly would be worth checking out, however when it cranks with the electric start, it spins over just as fast as it normaly does, I could maybe see if it was a little slow going but it spins over just no fire it seems. But I will check the volts, I got a multi-meter so no problem there, I will keep ya posted! Thanks
4xrider
Apr 10, 2017 01:36 PM
rmx251
Sep 10, 2000 11:40 PM
mrdci
Feb 7, 2000 07:16 PM
mrdci
Dec 4, 1999 11:03 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
