kfx 80 2 stroke mix in exhaust
messed this post up but , had 2 stroke mix in exhaust came out when tryin to start then i drained the remainder but won't turn over now just a clik on starter battery is still strong meter reads 12.3 vdc
dont know what to do never seen or heard of anything like this not sure how 6-8 ounces of fluid got there when this newer 2003 model with less than 20 hrs on it ?? any help would be appreciated.
Your motor is full of fuel.Pull the spark plug and turn the motor over till all fuel is out.
Use a rag to catch the gas AND make sure the spark plug wire is as far away from the rag and any ground as you can.
This happens, rare, but it happens. Clean the carb and make sure you remove and clean the brass needle seat.
Alex Rodak
Sep 12, 2015 09:39 AM
Sep 10, 2015 01:56 AM
