pull start leak shield
Old May 31, 2005 | 09:26 AM
Live2Mud's Avatar
Default pull start leak shield
I just got my engine rebuilt and had seen that highlifter came out with a pull start leak shield i dont want too have to pay that bill again. I tried silicone but obviously it didnt work. Has anyone seen these plates or used them. Thanks for any info.
Old May 31, 2005 | 03:02 PM
pat89's Avatar
They are very popular. I have used one now for about 2 years. They totally take away your recoil starter. You will need an air impact to remove the pull-start bolt and to replace it. The shield is clear so you can see if it's leaking. there is a gasket around it which can eventually deteriorate but can be replaced with blue rtv. The directions say to torque the three bolts back to 4 foot pounds to avoid cracking the clear cover but I have yet to find a torque wrench that goes down to 4 pds, so I just carefully hand tightened them.
Old May 31, 2005 | 04:50 PM
Live2Mud's Avatar
Do you have to take the recoil starter all the way off or does it bolt back up?
Old May 31, 2005 | 07:20 PM
pat89's Avatar
You have to take it all the way off. In other words, you will no longer be able to pull start it. The shield will bolt up to where it used to be. I take a booster pack with me or jumper cables on trips incase the battery is dead.
Dammar
Nov 14, 2015 07:41 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
