250r key
Old Jun 1, 2005 | 03:40 PM
RJV140's Avatar
Default 250r key
hello all i just am about to finish my 88 250r, my concern is that it does not have a key. it does have a kill switch, however i would like to have a key aswell. the bike has a atc 250r wireing harness (i believe it is almost the same as the trx) my question is if i buy a key set up from ebay what one from what other model would work with my harness and where do i hook it up to my harness.
thanks
Old Jun 1, 2005 | 04:20 PM
Semms40oz's Avatar
Default 250r key
Any two wired key setup will work. where u wire it in to your harness depends on wether the key-switch is open or closed when its turned to the run position.
Old Jun 1, 2005 | 06:02 PM
RJV140's Avatar
Default 250r key
what do you mean open or closed???
if its open where do you mount it?
if its closed where do you mount it?
Old Jun 1, 2005 | 06:59 PM
Semms40oz's Avatar
Default 250r key
ok think of 2 peices of wire.... when u turn the key to run you are either connecting the 2 wires (closed when turned to run) or seperating the 2 wires (open when turned to run).
If the key switch is open when turned to run it can be wired right in with your kill switch. if it is closed when turned to run you can wire it in between a major ground wire (one that must be grounded for the bike to run) and the frame.
Old Jun 1, 2005 | 11:44 PM
RJV140's Avatar
Default 250r key
ok thanks alot it sounds pretty easy im sure i can figure it out. im gonna start hunting ebay
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
