bayou 300 piston
Old Jun 2, 2005 | 08:55 PM
CHRACEING38's Avatar
Default bayou 300 piston
looking to find a piston over sized for a 2000 bayou 300.
The one's I have found are in the 120$$ range.
dose anyone know of a online dealer who has 77mm piston for a resonable price??
Thanks Gil
Old Jun 2, 2005 | 09:57 PM
holeshotz8436's Avatar
check out www.cycleworksracing.net, they have namura piston kits for 85 bucks, but you will need to click on the mojave-lakota section and go down to the lakota parts, they dont have any bayou spacific parts but the lakota and bayou have the same engine so the piston will work just fine
Old Jun 3, 2005 | 07:47 PM
so what othere parts will work with a bayou from the lakota??
Im going to buy that piston there price is right and service looks good from that company.
Thanks Gil
Old Jun 3, 2005 | 08:00 PM
basically any internal engine part because they have the same exact engines but the outer cases are slightly diffirent to fit the diffirent frames so im protty shure no outer cases will fit but things like cams, cam chains, pistons, carbs, throttle cables, top end gasket kits, valves and conncecting rods are all interchangable.............i also think the friction plates/steel plates and springs for the clutch are interchangable but im not positive..............cwr is a great company and the owner greg is a great guy to deal with and he is very knoladgable, nevermind that he makes some sweet performace parts for bayous/lakotas such as the 335 and 350 kits, oversized valves and lifted cams
Old Jun 7, 2005 | 05:20 PM
pitdog's Avatar
The Lakota Sport has a little bit more cam timing than the Bayou is the only difference.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
rcappie4
Sep 9, 2015 07:04 PM
