350X rear axle nuts (spindle)
Old Jun 3, 2005 | 09:37 AM
trappg's Avatar
Default 350X rear axle nuts (spindle)
I was so lucky as to buy an 86 350x recently. I'm in the process of "fixing her up". Previous owner obviously didn't know what he was doing on a few things. My question is about the rear axle. The spindles were just loosely mounted to the axle to the point that the wheels would rattle around on the axle spines. Aren't these axle nuts supposed to be tight to the point there is no slop? I tightened them down and re-set the cotter pin so there is no rattle. Can someone verify that I did this right?
Gary
Old Jun 3, 2005 | 02:37 PM
action450s's Avatar
yes, they should be tight, if they loosen up again the likely culprit is a bad wheel bearing. Make sure you dont ever tightenen the nuts to prevent the wheel from turning without too much resistance. If it doesn't turn smoothly, you may have to replace the bearing.
Old Jun 3, 2005 | 04:17 PM
trappg's Avatar
John, there are no bearings out at the spindle on a 350x. Bearings are at the swingarm. Thanks.
Old Jun 3, 2005 | 10:08 PM
TractorPacker's Avatar
Do you have a balloon?
He was right about needing to keep those castle nuts tight. You don't want the rear hubs to move at all. If they get play , the axle or hub will strip and then its done.
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
toonces
Aug 5, 2015 05:55 PM
Rider252
Jul 6, 2015 03:37 PM
