400ex carb
Old Jun 3, 2005 | 12:29 PM
hannahj's Avatar
Default 400ex carb
i just put a 42 pilot jet in bike and now i notice that its leakin somewhat of a lot of fuel from the overflow i checked to see if there was any mud in the carb but i didnt see any and i pulled the needle out 2, do i need to do anything else to my carb since i put the pilot jet in it or is it just getting to much fuel thanks
Old Jun 3, 2005 | 08:51 PM
hannahj's Avatar
Default 400ex carb
it only leaks when i smash on the gas is that normal to have some gas come out of the overflow
Old Jun 4, 2005 | 06:59 PM
1988fast250x's Avatar
Default 400ex carb
you can try and get a rebuild kit for it that might help!
i had 2 get a hole new carb for mine couldn't figure it out just kept on leeking from the over flow i even did the rebuild kit
the carb cost 300+ from carb parts warehouse its a mikuni flat slide
Old Jun 5, 2005 | 04:11 PM
cals400ex's Avatar
Default 400ex carb
if it is leaking out of the overflow, i would tap on the carb with a hammer. it sounds like the float may be sticking a bit. you may even want to take the carb and float apart and clean it. oh wait, i see you have a 00 400ex. in 01 they revised the float assembly. i would buy the new float pin/assembly.
Reactant
Mar 30, 2022 02:08 AM
GregM
Jul 29, 2015 09:41 PM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
