Pred jetting, help?
Old Jun 4, 2005 | 03:59 PM
Morewood's Avatar
Default Pred jetting, help?
03 TLD stock carb.
I am drilling out the brass covering over my air screw. I see two brass coverings, so which is covering the air screw?
Looks like the one that is protruding about 3/4 inches down from the carb body (when installed) would be covering the air screw. ???
Can anyone confirm? RAJ, do you know?
Old Jun 7, 2005 | 02:49 AM
Hawkeye01's Avatar
its the one that protrudes from the carb. There will be a treaded hole on each side of it. Do not drill the brass plug on below it.
Old Jun 7, 2005 | 02:13 PM
Morewood's Avatar
So I drill out the brass plug in the protruding post that sits between the two threaded posts?
What do you mean when you say: "Do not drill the brass plug on below it. " ??
The air screw is actually called the "Pilot Mixture Screw" in the manual, factory set at 2.5 turns?? Is this right?? I should find a screw, a spring, a washer, and an o-ring??
Do you know how thick the brass plug is? I don't want to overdrill.
Thanks for your help!
Old Jun 7, 2005 | 02:51 PM
Hawkeye01's Avatar
drill the brass plug on the post. drill very slow so you do not damage the screw below, all you will find underneth is a screw.
Factory settings is 2.5 turns out. So if you tighten the screw all the way down. Then unscrew 2.5 turns your at factory.
Old Jun 7, 2005 | 06:45 PM
Morewood's Avatar
OK, thanks.
The manual says the brass plug is called a "welsh plug". I've never heard that term before...have you?
What size bit would you use? About half the diameter of the plug?
Old Jun 7, 2005 | 11:32 PM
RAJ's Avatar
RAJ
Originally posted by: Morewood
OK, thanks.
Yes somthing alittle smaller then the plug, my plug had a little hole in it already from factory.
Old Jun 8, 2005 | 01:38 PM
Morewood's Avatar
OK, thanks a lot guys....I will be drilling that sucker tonight!
I went up to a 165 main jet with my new header pipe and I will give that a try. I am running a 50 Pilot Jet instead of the stock 45.
There is also a 42.5 jet that I have not touched...I think it may be the Starter Jet but I'm not sure...the manual is just not very specific on some of these details.
ReconBayou
Oct 31, 2022 05:37 PM
BYC
Sep 25, 2015 02:10 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
