whats louder
wow...with the disc type silencer you add discs to increase flow (and hp). think about it. if u take discs out u take away room for exhaust gas to escape. unless u are talkin about not using the back solid plate. as far as makin it louder the more discs u have in place the louder it should be. again unless u arent going to use the back plate.
not really cause if u have less discs less quite cause not as much air gets out and wen more discs more air comesout then more louder
if u take discs out there should be less of a gap. if there are spacers between the plates u are suposed to take those out too! "The disc type spark arrestor system allows you to tune the noise level. Our system tuned for peak HP running all 12 discs puts out a throaty sounding 101 dB. This is not acceptable for many riding areas. With the disc type system you can simply remove discs to get to the range you need. At 6 discs you would be in the 93dB range. You will lose some HP as you cut the noise." this is a direct quote from CT Racing. their pipe uses the same silencer as the FMF. this fast250x guy doesnt know what hes doin. when u remove discs there should still be the same gap between each disc, and the endcap would get closer to the end of the muffler. how he is running the system it is louder with less discs but that is simply because he doesnt know what hes doing. sorry about the short book but i didnt want anyone to me misinformed.
exmotocrosser
Sep 13, 2019 06:12 AM
