whats louder
Old Jun 8, 2005 | 02:25 PM
yvillanz's Avatar
Default whats louder
on the fmf megamax whats louder 20 discs or no discs?
Old Jun 8, 2005 | 02:54 PM
maddog56's Avatar
Do you want to be smacked now or later?
Old Jun 8, 2005 | 09:52 PM
1988fast250x's Avatar
no discs b/c i have one!! the less discs you have the more top end the more the more bottom end!
Old Jun 9, 2005 | 02:28 PM
TheTurtle's Avatar
wow...with the disc type silencer you add discs to increase flow (and hp). think about it. if u take discs out u take away room for exhaust gas to escape. unless u are talkin about not using the back solid plate. as far as makin it louder the more discs u have in place the louder it should be. again unless u arent going to use the back plate.
Old Jun 9, 2005 | 05:04 PM
raptorider660's Avatar
more discs= more power and louder less discs= less power and quiter
Old Jun 9, 2005 | 08:12 PM
no thats not true the more discs you have the more tourqe you have and the more quieter it is and if you have no discs on it then thats the loudest and then the more topend you have i have the pipe i know!!
Old Jun 9, 2005 | 08:23 PM
not really cause if u have less discs less quite cause not as much air gets out and wen more discs more air comesout then more louder
Old Jun 9, 2005 | 08:34 PM
im talking NO discs at all theres a 2 or 21/2 inhole there its louder i just took mine off to drag my uncle and i put them on 2 mx race but i only use 10
Old Jun 9, 2005 | 10:18 PM
TheTurtle's Avatar
if u take discs out there should be less of a gap. if there are spacers between the plates u are suposed to take those out too! "The disc type spark arrestor system allows you to tune the noise level. Our system tuned for peak HP running all 12 discs puts out a throaty sounding 101 dB. This is not acceptable for many riding areas. With the disc type system you can simply remove discs to get to the range you need. At 6 discs you would be in the 93dB range. You will lose some HP as you cut the noise." this is a direct quote from CT Racing. their pipe uses the same silencer as the FMF. this fast250x guy doesnt know what hes doin. when u remove discs there should still be the same gap between each disc, and the endcap would get closer to the end of the muffler. how he is running the system it is louder with less discs but that is simply because he doesnt know what hes doing. sorry about the short book but i didnt want anyone to me misinformed.
exmotocrosser
Sep 13, 2019 06:12 AM
XxS0ccerstarxX
Aug 29, 2015 10:21 PM
HondaR24
Jul 21, 2015 12:12 PM
brad wheeler
Jul 13, 2015 11:19 PM
Mike Frey
10
Feb 11, 2000 10:25 PM
