250r idleing
Old Jun 10, 2005 | 10:23 PM
Beefy400's Avatar
Default 250r idleing
i cant seem to get the R to idle without giving it some gas because if i dont give it gas it will stall. what should i do to adjust the idle??
Old Jun 10, 2005 | 10:30 PM
LittleBill's Avatar
isn't there a trottle adjustment screw somewhere on the carb or throttle cable?
Old Jun 11, 2005 | 12:06 AM
Jman68's Avatar
Yes, there is an Idle adjustment. It is on the choke. Turn the choke clockwise to make it idle high, and counter clockwise for a lower idle (i think...been a while since I had my R)...its a pretty dumb setup but it works.
Old Jun 11, 2005 | 03:17 AM
Beefy400's Avatar
i was playing with that but it didnt seem to work ill try again anything else i can do??
Old Jun 11, 2005 | 11:28 AM
Hoopie's Avatar
CHeck your throttle cable. You may have to adjust the cable.
Old Jun 11, 2005 | 01:35 PM
1BAD250R's Avatar
If thats not working your carb may be dirty. Clean it with carb cleaner then blow it out with compressed air. Worked for me when I had this problem 2 weeks ago.
Old Jun 11, 2005 | 02:26 PM
Beefy400's Avatar
i think the throttle cable is streched because there is some slack when i took the cover off the throttle box on the bars. do i need to buy a new one?
Old Jun 11, 2005 | 08:25 PM
dragracer789's Avatar
Try droping your pilot jet down one size. The throttle wont make a diffrence in idleing unless it has NO slack, so your ok with that.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
