Bearing Carrier question
Old Jun 13, 2005 | 01:25 PM
REDEX300x's Avatar
Default Bearing Carrier question
hey, i saw some after market bearing carriers and i wonder how do you install them, cuz the stock one is permantly thier no way to take it out and put other one...
does it fit only on aftermarket swing arms?
here is a link of what im talking about
http://cgi.ebay.com/ebaymotors/ws/eB...category=43972
Old Jun 13, 2005 | 01:46 PM
VT250X's Avatar
yu will need to get the bearring carrier out in order to install a new one. Did you remember to remove the carrier bolts from the back as well as the small bolt below it? If you did and it still doesn't come out, use a heavy screw driver or a small pry bar to spread apart the area where the rear lock bolts are lovated. If you can turn the bearing carrier to tighten or loosen the chain then it should come out if you follow the above idea's. Of course you would have to have remov your rear axle and everything else but the carrier and swing arm. If none of the above ideas work and you can't rotate the carrier then you have a serious problem. That carrier needs to come out or you need a new swingarm if you want to change it out.
LM
Old Jun 13, 2005 | 02:43 PM
quad2xtreme's Avatar
Your stock carrier can be removed. Just follow the instructions in the 300ex repair manual (a separate book you can purchase)
/Jon
Old Jun 13, 2005 | 04:28 PM
REDEX300x's Avatar
but it attached to the swingarm like built in it, isnt it?
Old Jun 13, 2005 | 04:38 PM
VT250X's Avatar
No it is not built in. You should be able to rotate it. If you haven't already remove the two rear bolts that lock it into position along with the small stop bolt located underneath the swingarm. Take a screwdriver or a small pry bar and spread the rear lock bolt mounts a bit. you may have to take a rubber mallet or similar item to get it to move, but it will come out.
LM
Old Jun 13, 2005 | 05:30 PM
300exfreak's Avatar
i just changed the bearing carrier in my 300ex its very simple to do. first loosen your axle nut it will make things go easy for ya. and i recomend the rad because it has the brake caliper holder on it already
Old Jun 14, 2005 | 12:21 AM
8dave3's Avatar
Something else,isnt there a snap ring holding the brake stay on?
Old Jun 14, 2005 | 12:41 AM
VT250X's Avatar
Yes there is. I completely forgot to mention that. I wonder if thats why he can't get the carrier out. Good call [img]i/expressions/face-icon-small-smile.gif[/img]
LM
Old Jun 15, 2005 | 08:58 AM
Another thing that can happen to lock you carrier in even to the point you can't adjust it is putting on a replacement skidplate and using bolts that are too long. It is possible to screw the bolt through the swingarm until they rest against the carrier.
I run into this on a couple of times.
/Jon
Old Jun 16, 2005 | 10:14 PM
honda400rider's Avatar
There are a number of snap rings that need to be removed along with the bolts on the rear of the swingarm. Then take a 2X4 and put against the inside of the swingarm where the bearing carrier is. Then hit it with something big.
Ean
Dec 19, 2022 08:48 AM
austinwhitton
Aug 11, 2015 06:21 PM
akbrewcrew
Aug 9, 2015 10:54 PM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
