Sport Quads Discussions on sport quads.
Broken Shee . HELP
Old Jun 15, 2005 | 08:37 PM
trailblazerpimp's Avatar
Default Broken Shee . HELP
awesome.. so my banshees throttle has been sticking latley. ill be riding down the trail and it will stick, ill pull in the clutch rev it quick and it goes down to an idle again but now i cant even start it because when i do it revs wide open so i have to shut it right down before it blows up . ive opened my throttle box sprayed WD-40 all over the box and cable and thats not it.. i checked the carbs to.. nothing.. HELP PLEASE
Old Jun 16, 2005 | 09:00 PM
ridinsmooth's Avatar
well have you checked your throttle body on your handle bars..
Old Jun 17, 2005 | 03:16 AM
Jibrille's Avatar
ridinsmooth, throttle bodies are on EFI motors are they not?
trailblazer, Try a little greease or something on the springs I don't know. Nothing is lose in the carbs at all? Maybe even check your throttle cable to see if it sticks there and it holding the carbs wide open.
Old Jun 17, 2005 | 04:36 PM
Kawizuki400's Avatar
There is always a chance that the cable is actually binding inside of the sleeve. If you have the money, buy a new cables. I mean only one of them could be binding and that would be enough. Remove the cables and try to slide the cable in and out of the housing to see if thats the issue. Just a thought.
Old Jun 18, 2005 | 06:50 PM
TooFast2Pass's Avatar
If the stock TORS are still on, there are many variables. It could be the throttle housing up at the handle bar. From there you have a single cable that runs down underneath the tank and then splits into 2 cables and goes into the TORS system. Then the TORS pulls a separate short cable per carb which actuates the slides. It could be in any of the cables/TORS. If all that checks out then the slides are sticking to the carburetor body. Check everything for free movement.
Old Jun 19, 2005 | 09:41 PM
YFZ450kid's Avatar
WD-40 is the problem, its a great quick lube, but for long term it gets really gunky... change your throttle cable and check all the springs...
Old Jun 24, 2005 | 11:46 PM
RDZ350's Avatar
Find where the throttle cables from the carbs and meet the cable from the throttle.The cables from the carbs can slip out from where they meet.Make sure the cables are in good and wrap them with electrical tape.That seemed to work for the stock throttle cable.
Old Jun 25, 2005 | 01:48 AM
TractorPacker's Avatar
Do you have a balloon?
Mine did that to me the first time I went to race it. First corner first heat up side down and under the quad. That sucked. I changed the cable then the housing then the carbs. It went away with different carbs. I then switched the old slides in the new carbs and it came back. The slides were grooved up and caused friction, causing them to hang in the carbs. They are coated with a greyish black coating. If that is scratched up, try new slides.
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
awer1968
Sep 8, 2015 11:02 AM
