lt80 hot wire
Old Jun 20, 2005 | 02:03 PM
stevendsm95gst's Avatar
Default lt80 hot wire
lost the key to my lt80. I figured it would be easy to just bypass the whole ignition system anyways. Does anyone on here know what i need to do?
Old Jun 20, 2005 | 05:48 PM
LT80's Avatar
LT80 Expert
Cut the wires that go to the switch and strip/twist them together.
Old Jun 21, 2005 | 01:50 AM
there are 4 wires i believe. I just splice them all together?
Old Jun 21, 2005 | 01:13 PM
LT80's Avatar
LT80 Expert
Sorry, you will need to use an ohm meter to find the correct 2 wires from the key switch.
You can eliminate all the switch stuff by connecting the motor wires directly to the coil wires and use a tether switch.
FYI: if you are still using the electric start, all this isn't a great idea as the system would be on all the time. Right?
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
400H0
10
Aug 20, 2015 07:34 PM
frostphase
Aug 19, 2015 07:11 PM
Bergmann
Aug 13, 2015 03:51 PM
DeFox500
Jul 26, 2015 06:32 PM
