how do you get a rear cv shaft out of a 700?
Old Jun 20, 2005 | 06:55 PM
silverbullet2005's Avatar
Default how do you get a rear cv shaft out of a 700?
I am in the process of taking my cv shaft out from the rear of my 700 sportsman, I have the axle nut off and the hub off along with the complete lower control arm assm. all that's left is to pull the shaft out from the rear diff. and it won't come out, I have tried a prybar and a thick screwdriver. any tricks I should know about from anyone who has replaced a shaft/cv?
Old Jun 20, 2005 | 07:05 PM
thewayout420's Avatar
is there a clip on the back side holding it in?
Old Jun 20, 2005 | 07:32 PM
SPORTSMAN70003's Avatar
In my manual it says to pull sharply outward. I usually use a prybar [img]i/expressions/face-icon-small-smile.gif[/img].
Old Jun 20, 2005 | 08:18 PM
Kerbbirds's Avatar
I use a short piece of 1/4 inch chain fastened on the axle and attached to a slide hammer, a couple of good wacks should do it
Old Jun 22, 2005 | 10:30 AM
I tried a prybar somewhat but it doesn't fit behind the shaft very well. I guess I'll try giving it another shot and try a few other things as well. thanks for the replies.
Old Jun 23, 2005 | 07:54 AM
floodrunner's Avatar
A straight pull with a slide hammer is best, if it won’t come out with the “sharp pull” method. You may get lucky with a pry bar but unless you use two (on behind each side of the CV cup) you may force the splined stub to one side or the other, making it more difficult to extract.
slowgsxr97
Sep 8, 2015 04:37 AM
snowolson
Aug 31, 2015 03:51 PM
Dan Newberry
Aug 30, 2015 09:42 AM
Dammar
Aug 26, 2015 07:12 PM
tporath
Jul 11, 2015 12:31 PM
