Problems With Shifting Cyclone Into Gear...
Old Jun 22, 2005 | 12:30 PM
SuckMyMuffler's Avatar
Default Problems With Shifting Cyclone Into Gear...
My budy has an old Polaris Cyclone 2-stroker and it idles fine in neutral. When you go to shift it into gear(its an automatic) it will go into gear but then it dies as soon as it shifts into gear. What could be the problem? We were thinking it may be the belt is too tight and may slow the engine down so much when it goes into gear that it dies but im not real sure. Anyone have any suggestions?
Old Jun 22, 2005 | 01:18 PM
fishslab's Avatar
Your probably close, but it's more likely your springs in the clutches and your buttons are bad. The clutches aren't opening up to let the belt drop down far enough to idle.
Old Jun 22, 2005 | 01:33 PM
DanMan83's Avatar
You might want to check the idle adjustment screw, it may be too low. Warm it up for about 5-10 mins then raise the idle a little and see if it helps.
Old Jun 23, 2005 | 12:33 AM
ScramaDamaDingDong's Avatar
you got it bro. weak spring
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
