Headgasket?
Old Jun 24, 2005 | 01:05 PM
cripplednomore's Avatar
Default Headgasket?
Would a headgasket failure cause it to lose pressure at higher rpm? Iwas taking the quad apart to check carb and I noticed smoke from where the exaust meets the head. Little pieces of gasket sticking out inbetween the head and block. If so how hard is it to replace? and about how much$$. Thank you!
Old Jun 24, 2005 | 08:39 PM
ATVnRocks's Avatar
Default Headgasket?
The little dimple that sticks out is normal, probably has a tiny rivit in it. The leak is probably the valve cover gasket & cover warped.
Old Jun 24, 2005 | 11:54 PM
ScramaDamaDingDong's Avatar
Default Headgasket?
shouldn't be that hard or that expensive just pull the head bolts out. scrape off all the old gasket and putt it back together using factory torque specs
Okee Wheeln
Mar 6, 2013 08:21 AM
cwnoble
Aug 7, 2009 03:51 PM
chenoweth122
Nov 3, 2007 04:12 PM
KeninAZ
Oct 14, 2005 07:31 PM
rdnred
Jul 26, 2005 10:26 PM
