no tension in my clutch cable! help please quick
Old Jun 25, 2005 | 11:05 PM
yrrej's Avatar
Default no tension in my clutch cable! help please quick
ok i took my clutch cable off and i went to put it back on and there is no tension....like it has too much slack ...i been stumped all day....what should i do...its the stock cable. please no bullspit answers
Old Jun 26, 2005 | 01:51 PM
yrrej's Avatar
anyone? please?
Old Jun 26, 2005 | 03:13 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
where did you take it off of? which end? if you took it off the crank case cover.. did you put the spring back on it?
Old Jun 26, 2005 | 03:16 PM
yrrej's Avatar
first i took it off the lever end to make slack so i could get it off the clutch cover end...wat spring? the big long 1 that is like half the cable?
Old Jun 26, 2005 | 03:19 PM
Speedy2222's Avatar
nnoo on my warrior there's a spring on the case to keep it with constant tension..
Old Jun 26, 2005 | 03:26 PM
yrrej's Avatar
ya is that the 1 that kinda wraps around the little lever on the case? mine is on there........just seems like the cable is to big but it is stock? im so cofused? would it matter if i changed the course of tha cable at all....like maby around the steerring stem to make it a little shorter? ps i have never had such a stupid problem
Old Jun 26, 2005 | 03:28 PM
Speedy2222's Avatar
length sometimes does affect it.. but i know on my warrior if the perch isn't adjusted right it will be either really tight or really loose.
Cummins Driver
Sep 11, 2019 01:22 PM
firsttimerider
Technical and How-To Articles
Sep 7, 2015 11:43 AM
Cantbuytime
Aug 17, 2015 06:33 PM
gamer17
Aug 15, 2015 12:38 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
