Porting
Old Oct 12, 2000 | 11:55 AM
tbass2's Avatar
I was wondering how much porting would change my engine timing and if it would require increased jetting?
Old Oct 12, 2000 | 05:10 PM
Backcountry's Avatar
Engine timing? Do you mean port timing or ignition timing. The ignition timing is independent of any head or cylinder modifications. Typically though the timing is adjusted to better compliment the new head mod's or port timing mods.
An increase in jetting. Yes, typically, everyone's port work is different, so how much differs. By porting the cylinder you're getting it breathe better, and if your porting a cylinder head, you're doing the same thing.
Old Oct 12, 2000 | 07:54 PM
trapperb1's Avatar
I agree with Backcountry if you're porting a 4 stroke.
If you're porting a 2 stroke, it might change your port timing depending on how you have it ported.
Old Oct 22, 2000 | 05:49 PM
jonney's Avatar
Port timing is controlled by a cam on a 4 strokeand the piston on a 2 stroke by cutting on a 4 stroke it dosn't affect the cam timing.But on a 2 you can lower the ports that will change it
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
