Where can i get jets for cheap
Old Jun 29, 2005 | 12:58 AM
DanMan83's Avatar
Default Where can i get jets for cheap
Does Anyone know where i can buy a very large asortment of jets for a pretty good price
I mean i wanna buy alot in one package deal
and a tach and an air/fuel meter
Old Jun 29, 2005 | 01:01 AM
Steve10's Avatar
Sudco.com for jets.
Old Jun 29, 2005 | 01:12 AM
DanMan83's Avatar
they dont have polaris jets there naybe i missed something that you could direct me to
Old Jun 29, 2005 | 07:36 AM
Oleman's Avatar
Polaris uses Mikuni carburetors. Sudco will have anything you need.
Old Jun 29, 2005 | 10:52 AM
2manytoys's Avatar
Why do you need all the jets? You can get jets at your local atv or Polaris shop for about $1-2 a piece.
Old Jun 29, 2005 | 01:43 PM
ScramaDamaDingDong's Avatar
the Air/fuel meter will be very hard to find cheap. The cheap ones that you see use a narrow band O2 sensor and a simple led readout or even a gauge with rich stoich lean. The problem is that these are designed for 4 cycle engines with stoich being 14.7:1 and the stoich for 2 cycles is 12:1 so when your engine is running in a stoichiometric state the A/F meter would read rich. You need an A/F meter with a digital readout and a wide band O2 sensor so you can tune to the 12:1 ratio. There are several out there but they are very expensive. You can build your own but it is somewhat complicated. You can search the web for DIY air/fuel meter and find some resources if you want to do it yourself. The cheapest A/F meter that I have found with a digital readout is 300-400 dollars. You may want to look into an exhaust gas temp gauge. With the EGT gauge you can tune the engine also but it is not as accurate as an A/F meter.
Old Jun 29, 2005 | 07:04 PM
DanMan83's Avatar
ok thanks
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
