Any ideas
Old Jul 2, 2005 | 11:44 PM
rsking45's Avatar
Default Any ideas
My friend has a 04 600sp and his son rolled it, didnt get hurt but is a little wiser now.
The problem that he is having with it is that it will idle fine but when the rpms get close to 3500 it starts to spitt and sputter as if not getting enough fuel,or when at idle and you open the throttle wide open it will skip and keep skipping untill you let off the throttle.
We checked the air box for oil and none there,plugs look fine.
Any Ideas
Old Jul 3, 2005 | 12:20 AM
farmerboy's Avatar
Default Any ideas
if you can run it in a clean area i would take the airfilter off and see if it helps. if it does replace your air filter.
Old Jul 3, 2005 | 10:19 AM
rsking45's Avatar
Default Any ideas
we tryed that and it will still do it
rich
Old Jul 3, 2005 | 01:35 PM
carpenter's Avatar
Default Any ideas
I KNOW THIS SOUNDS STUPID BUT CHECK THE CARB JET. IT COULD HAVE GOTTEN BROKE IN THE ROLL.
Old Jul 3, 2005 | 02:54 PM
ScramblerKid8's Avatar
Default Any ideas
Look at where your fuel line is running. It might be pinched offenough only to allowenough gas for idle. Also check your fuel filter.
Old Jul 4, 2005 | 10:47 AM
Kerbbirds's Avatar
Default Any ideas
take the top off of the throttle control and se if something got broken in there, may also be out of adjustment, should be just a little bit of slack in throttle cable, not much.
fordfaithful21
Dec 7, 2015 05:52 PM
PrairieDog126
Sep 12, 2015 06:53 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
