Prairie 700 Noise from converter housing
Yesterday a noise started coming from my convrter housing. It's hard to discribe noises to people but it was a howling, vibrating kind of noise.it makes it in high and low gear not reverse. it only does it while driving not at idle, even if its in gear. this noise is pretty loud. if i disconnect the engine braking system actuator it won't make the noise. I'm wondering if there is a bearing in the COVER-COMP on the dirve converter that would be like a thow out bearing that the lever-comp rides against or if the bushing in the drive converter could be causing this?
What do you guys think?
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
