YFZ Shocks
Old Jul 6, 2005 | 10:09 AM
Raptorx44's Avatar
Default YFZ Shocks
Just won some yfz shocks for the raptor on ebay and need some help on the conversion. Did a search but found nothing in detail. Any help would be greatly appreciated.
Old Jul 6, 2005 | 12:10 PM
Raptorx44's Avatar
Default YFZ Shocks
Anyone?
Old Jul 6, 2005 | 12:55 PM
warriorboy22's Avatar
Default YFZ Shocks
i might buy your stock raptor shocks if u are looking to sell them
Old Jul 6, 2005 | 03:22 PM
Raptorx44's Avatar
Default YFZ Shocks
ok ill let u know
Old Jul 6, 2005 | 03:31 PM
Raptorx44's Avatar
Default YFZ Shocks
Anybody out there got yfz shocks on their raptor?
Old Jul 6, 2005 | 04:44 PM
warwgn's Avatar
Default YFZ Shocks
it is easy you need to grind off some of the metal on the lower a-arm shock mount and grind on the lower back side of the bottom shock mount to round it off for clearence. then they will go right in.
Old Jul 7, 2005 | 10:53 AM
natex14's Avatar
Default YFZ Shocks
On the top mount, you will need to take like 1/8 inch off. Once you do that put the shock in there and see how it fits. Make sure it won't bind when your shock compresses. The bottom mount on the a-arm is shaped like a U, make it into two I I, just remove the back piece that is closer to your steering stem.
It's real easy, you will see exactly what you have to do as soon as you put that shock down there in place.
It makes a world of difference, you won't be disappointed.
Good luck,
Old Jul 7, 2005 | 10:57 AM
Raptorx44's Avatar
Default YFZ Shocks
Im trying to visualize and i think i understand. They should be here tomorrow. So i do not have to grind the shock just the top mounts on the frame and the bottom a-arms?
Old Jul 7, 2005 | 11:07 AM
natex14's Avatar
Default YFZ Shocks
You got it, it's much easier than it sounds. Three beers and 45 mins (if you take your time) and you will be done.
Old Jul 7, 2005 | 11:10 AM
Raptorx44's Avatar
Default YFZ Shocks
Cool, i know that it will handle landings better but what about over all handling did u you notice any difference? Also does it lower the front any i've heard it does and that it does not.
