problem Need a fast response please
Old Jul 8, 2005 | 07:22 PM
monster88's Avatar
Default problem Need a fast response please
sup guys.. i have a 2001 honda 400ex. Im currently trying to install a new steering stem. I got the old one out and i need to replace the bearings also. The bottom bearing is rusted in. I cannot get it out. I tried wd40 and everything.. Is it supposed to come out from the top or the bottom? Any suggestions?
Old Jul 8, 2005 | 08:22 PM
quad2xtreme's Avatar
After you take the steering stem out, look for an internal c-clip on the top side of the bearing. Remove it and then pound out the bearing from the bottom of the quad towards the gas tank. Helps to just stand the quad up on the rear grab bar (turn the gas off). You will have to remove the skidplate if you have one.
good luck.
Old Jul 8, 2005 | 08:53 PM
monster88's Avatar
Ohh theres a c-clip?? Hmm.. Its on the top on the bottom? Im guessing its on the top? Thanks for the help
Old Jul 8, 2005 | 11:53 PM
monster88's Avatar
ok well i took out the c clip. I got the middle part of the bearing out... The sides are still stuck in there *cry* What can i do? I sprayed rust remover spray on it and im gonna let it soak overnight. It seems that the sides of the bearing is all the way at the bottom and it needs to be pushed down rather then pushed up. I will take some pics tomorrow and show u guys what im talking about. Anymore suggestions? Im ready to just bring it to the dealer becuase im so fed up with it. But that will be my last resort.
Old Jul 9, 2005 | 12:42 AM
rdnred's Avatar
I had the same problem on my R's bearing. I tried everyrthing to get it out, finally i had to take air chisel and put a punch in it and that finally got it out. I sprayed it with PB blaster and everything to try to get it out. Finally the air chisel got it out.
Old Jul 9, 2005 | 12:14 PM
monster88's Avatar
ok well ive been trying to get this now. Im currently working on it. Like i said before, the middle part of the bearing is out. It seems like the sides are still in there but my friend does not think so. Im gonna try and put the bearing in today.. and see what happens. hopefully it will work..
Old Jul 9, 2005 | 12:58 PM
You should know whether the outer race came out with the bearing. If the bearing was in pieces, you are probably right that it is still in there. You have to drive it out with a socket that just fits. You drive it out from the bottom with the quad standing up on end.
You could also use a dremel with the wheel cutter to slowly cut through the outer race.
Old Jul 9, 2005 | 01:21 PM
ixRAZORxi's Avatar
find a socket the same size as the bearing and smash it out. If there is room. I have neverlooked at one
Old Jul 9, 2005 | 06:11 PM
monster88's Avatar
nice i got it.. thanks for ur help guys. The air chisel worked.
Old Jul 9, 2005 | 09:31 PM
Thought I was gonna have to drive up there to fix this for you. j/k [img]i/expressions/face-icon-small-wink.gif[/img]
Ramman1
Jun 16, 2016 09:07 PM
JackTheKing
Jul 14, 2015 09:09 PM
steveo612
Jul 11, 2015 08:35 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
Jul 7, 2015 11:00 PM
