300ex shock broke
Old Oct 13, 2000 | 11:00 PM
jeepin's Avatar
2 weekends ago my front right hand shock on my 97 300ex broke!!!!!It broke right at the bottom where it bolts on to the a-arm. We had to ride it home about 4 miles through valley's and creeks.It was very scary I was thinking I was going to break something else.Any way we went home and I got my stock 250r shock and found that it was way to long.So we removed the spring from the ex shock.We removed the spring from the r shock and swapped em we had to make an aluminium spacer to make up the difference.It worked alright.It bottoms alot.I juts jump more careful now.
has any else have this prob?
86 trx250r wiseco .020 piston,boyesen reeds,fmf gold series fatty pipe,power core 2 silencer,Dg alloy series nerfs,durablue eliminator 2+2 adjustable width axle,jd performance +2 A-arms,white bro's white power shocks with adjustable res's all the way around,nac's casesaver,braking brake pads,fastline braided steel brake lines,PEP easy pull clutch pull and lever,18/11/8 holeshot mx's on mitchell .190's,21/7/10 holeshots on ITP .190's,motion pro clutch clutch,uni filter
97 300ex 20/11/9 6 ply razr's on ITP .190's
96 warrior
90 blaster.
www.angelfire.com/me3/fmf86trx250r
Old Oct 13, 2000 | 11:25 PM
luckywilson's Avatar
NoI never broke a shock. But I did break the frame where the shock hooks up to. If you need a shock I have one off my 250x that is still good you can have for $25.00.
Old Oct 14, 2000 | 12:35 AM
ATVPRO's Avatar
yeah, A buddy of mine broke his on a 250x at the same spot you said. so I took it to the dealer and told them it was off of my new 300ex. this was back in late 95
Old Oct 14, 2000 | 11:55 AM
jeepin's Avatar
the thing was weren't jumping when it broke.I was driving down a dam by a lake and it juts broke I thought my front tire went in a hole or something.
Old Oct 14, 2000 | 02:39 PM
bid300EX's Avatar
same thing happened to my 300 in the same place, and i wasn't jumping at the time either. It had been leaking from there for a couple weeks though.
Old Oct 14, 2000 | 03:22 PM
ATVPRO's Avatar
It could have broke most of the way from jumping and finally cracked the rest of the way
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
