K&N filter messing with idle
Old Jul 9, 2005 | 08:14 PM
05PRED500's Avatar
Default K&N filter messing with idle
I did a search and couldn't find anything on this. My search criteria may be off though.
I installed a K&N filter into the stock airbox on my Predator and now she wants to shut off at idle. Once warm, it shuts off less. Other than that, I can tell that the throttle response is better and the butt dyno seems to pick up a little more power.
Should I need to adjust the carb just because of a filter change? I would have never thought it would make that big of a difference.
Any help is appreciated.
Old Jul 9, 2005 | 09:15 PM
spyder6's Avatar
its their garentee that you dont have to, but i would amagine with a large intake like that you might
Old Jul 9, 2005 | 09:17 PM
trailrider500's Avatar
You might have to play with the idle mixture, its probably a little lean with the filter.
TR
Old Jul 10, 2005 | 10:38 AM
hondabuster's Avatar
Lets face it, we buy those things, because there is a difference.
The kn will flow alot better, so the mixture is probably leaner. If the idle is the only problem, then make the idle circuit richer, by turning the mixture screw ccw.
A warm motor, will tolerate a lean mixture better than a cold motor will, thats why its worse when cold.
Old Jul 13, 2005 | 11:30 PM
ScramaDamaDingDong's Avatar
yeah, your lean at the bottom that's why it's cutting out on you
Old Jul 13, 2005 | 11:38 PM
Hoopie's Avatar
I put the choke on half way when starting it until it warms up and once its warm it starts fine. I have the same problem after i put mine in.
Old Jul 14, 2005 | 12:19 AM
05PRED500's Avatar
Thanks for replies. I didn't get to ride last weekend, but I plan to this weekend. It seems that once I warm up, it gets better.
COFatboy
May 2, 2020 12:06 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Ronk407NY
Feb 13, 2016 11:05 AM
house1
Aug 9, 2015 10:49 PM
Aitch
Jul 21, 2015 09:40 PM
