E-Ton Viper 90 running very funny
i have had this ATV for a little over a year now, bought new. The problem is when i start it the electric start is dead so i kick start it and it revs up alot when I'm on idle, also sometimes it will go and accelerate for itself. My uncle and I were outside to see what was up we put it on crates and started it i was actually flooring itself, and the wheel were spinnings at differen speeds, with out anybody holding onto the throttle. I don't know what to do so can you guys please help me. P.S. I think the gas is coming into rich also can u please help me!
[img]i/expressions/face-icon-small-sad.gif[/img]
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
Start with a good carb cleaning.
If still a problem, spray carb cleaner around the rubber intake boots between the carb and reed cage and listen for rpm changes.If it changes rpm's then you have an air leak there.
If that don't work then spray carb cleaner behind the front clutch to see if that crank seal is bad, then the stator side for that crank seal (again listen for rpm changes).
I'd almost bet there is an air leak, but I allways start with a carb cleaning.
Frisky2050
Apr 9, 2020 11:19 AM
bgky
Jun 29, 2015 01:40 PM
