425 mag misses fouls plugs
Old Jul 13, 2005 | 10:36 PM
polarbare21's Avatar
Default 425 mag misses fouls plugs
Help please,
My son's 96 425 magnum 4-stroke has a slight miss at low rpm's and fouls plugs, some smoke at high idle.
good gas, new air filter, new plugs. Any ideas?
Thanks
Old Jul 13, 2005 | 10:45 PM
ScramaDamaDingDong's Avatar
If the plug is oil fouling and your burning oil then you either have worn out rings or bad valve seals. If the engine has never been worked on it may be tired. The only simple thing I can think of is it's too rich at idle and if that's the case it will foul out plugs. What color is the smoke? if it's black then I'd say it's too rich if it's white your burning oil and need to rebuild if it get's to annoying for you
Old Jul 14, 2005 | 03:45 AM
jimmypsp700's Avatar
Try backing out the air screw a half or full turn for more air at idle and low throttle.
Jim
Big bousse
Sep 26, 2015 10:42 AM
JohnnySplat
Aug 6, 2015 12:07 PM
binky79
Jul 30, 2015 06:37 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
