Which cams ?
Old Jul 15, 2005 | 10:15 AM
Bellracing2's Avatar
Default Which cams ?
What cams would you recommend for a stock eng for more low + mid ?
Old Jul 15, 2005 | 10:22 AM
MrMeaner's Avatar
HPR
Old Jul 15, 2005 | 10:41 AM
SCOUNDREL's Avatar
HR3 Cams or HR2
Talk to Randall or Eric. I have the HR3's but I'm not stock.
Old Jul 15, 2005 | 10:56 AM
CountryJoeGlass's Avatar
I have the HPR-3 cams & I'm not stock. These cams work great.
Old Jul 15, 2005 | 12:10 PM
Ben do you plan on doing anything else other than the cams down the road? That will make a difference on the ones you choose. It also depends on your budget, some cams also require HD valve springs. My HPR-3 cams require the HD valve springs.
Old Jul 15, 2005 | 12:59 PM
DSengineer's Avatar
Has been here a long time!
What mods does your DS currently have?
Old Jul 15, 2005 | 01:11 PM
slip on pipe
Old Jul 15, 2005 | 01:39 PM
SCOUNDREL's Avatar
A direct quote from Randall at RECREATIONSPEC@AOL.COM
"Of course, all of our cam grinds (HR3, HR2, HR1, etc..) can be custom adjusted on duration and lobe center to you and your modifications, exhaust, weight, etc...."
Which is true. He asked several questions including my weight, riding style, terrain I prefer to ride, elevation, modifications I have done and which I expect to do along with a slue of other questions....
I asked if he needed to know how often I had sex but he said that wouldn't be necessary because he knows I'm married and I'm not getting any!!! [img]i/expressions/face-icon-small-blush.gif[/img].....LOL
Old Jul 15, 2005 | 01:54 PM
DSengineer's Avatar
Skip the cams at this point and go for a larger carb. TM45 or 46HV.
I have two DS's running 46HV's one with stock cams and one with HR3's. The difference between low/mid range is not that noticeable to me. Slight advantage to the HR3's. The HR3's really shine in the mid/upper range over stock cams. Now the difference in low/mid between stock carb and 46HV is very noticeable.
Old Jul 15, 2005 | 02:01 PM
OregonDunePatrol's Avatar
Buy some Web 110's or Web 109/110's and put the money you saved into a TM45 with a pump.
