How do I change the rpm's on the idle
Old Oct 14, 2000 | 11:23 PM
MagDaddy's Avatar
I have a 00 magnum 325 and was wondering how do I get to the carburetor I can't get passed the air filter.
00 magnum325 25'vamps, k&n high performance kit
Old Oct 14, 2000 | 11:27 PM
AKScrambler's Avatar
I haven't looked "under the hood" on the 325, but sounds like you'll have to pull the airbox. Should be easy enough.
Old Oct 14, 2000 | 11:33 PM
MagnumMudMan's Avatar
MagDaddy
I can't totally remember, but on the 325 engine, you should be able to get to the idle adjustment screw from the side. I think you can get to it with your hands from the left side of the vehicle. You should not have to remove the airbox for an idle adjustment.
Old Oct 15, 2000 | 02:11 AM
Houndog's Avatar
it's really easy - my dealer showed me how. Take off the seat, remove the plastic on the left side of the bike starting where the side panel meets the back fender. You just have to bend the side panel out and the plastic hangers let go. Look up behind it and coming out the bottom of the carb is a long adjustment screw. That's it ! Turn it in or out by hand according to where you want it and you're done. Pop the plastic side panel in place. They told me to set the idle with the bike in gear. If the idle is to high, the tranny will "crunch" when sliding into gear. Hope I've explained it well enough.
Houndog
Magnum 325
COFatboy
May 2, 2020 12:06 AM
Cummins Driver
Sep 11, 2019 01:22 PM
house1
Aug 9, 2015 10:49 PM
ghost civic
Jul 27, 2015 03:15 AM
ranvette
Jul 12, 2015 06:34 AM
