800 EFI Muffler Issue
Old Jul 18, 2005 | 10:32 AM
Cutty's Avatar
Default 800 EFI Muffler Issue
While giving my new 800 the once over I noticed my left muffler (when viewed from the rear) is actually touching the crossbar below it. The right side has about a 1/4" clearance. I tried loosening the clamp on the crossover pipe and moving the left muffler but really couldn't get it to budge. Anybody else notice this on their 800 or am I just special? Thanks
Cutty
Old Jul 18, 2005 | 11:07 AM
mtpockets's Avatar
you know, it doesn't take rocket science to notice the exhaust hitting the frame.
i think your DEALER did a lousey job and should have noticed the issue when they set-up your $9K ATV!
i would bring it right back and have the Dealer repair it......at the same time have them check the torque on your lugnuts. i'm sure they didn't!
~MT
Old Jul 18, 2005 | 07:55 PM
powerslider's Avatar
My 800 had the same issue with the left muffler, I noticed it at the dealer and had them correct it before I brought it home.....
Old Jul 18, 2005 | 08:02 PM
Cutty's Avatar
So how much room do you have below your mufflers? Did you watch them fix it? What did they do? I noticed that there is a frame part above the muffler also that doesn't leave much room for adjusting. My dealer is over an hour away and I'd like to fix it myself. Thanks
Cutty
Old Jul 18, 2005 | 08:13 PM
I didn't watch them adjust it, picked it up a couple days after I first looked at it. The left muffler has approx 3/16" clearance above the swaybar, you may have to tweak the hanger rods on the muffler to raise it up. Make sure it isn't too far in where the frame bolts will rub on the muffler body, mine was hitting the bolts and the swaybar.
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
zach1106
Jul 31, 2015 01:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
