let me clarify
Old Jul 18, 2005 | 11:44 PM
Perky's Avatar
Default let me clarify
when installing the k-n air filter on my 800 they said to seal the sealing edge of the filter with grease(is silicone grease ok?}
the sealing edge? is that the tip end of the filter where it goes against the ridge onthe air box or the inner side of the filter....dont laugh....youll be old some day too.....lol
Old Jul 18, 2005 | 11:54 PM
spyder6's Avatar
i dont think theres any need to, i didnt and have never had a problem
Old Jul 19, 2005 | 12:33 AM
EAB's Avatar
EAB
I've had 2 2000 TB250s and 2 2002 Scrambler 400s, and they all had grease on the sealing edge from the factory. Its insurence. It goes on the part of the filter that contacts the air box.
Old Jul 20, 2005 | 12:30 PM
ScramaDamaDingDong's Avatar
as EAB said you would put a light coating of grease on the bottom of the filter so you get a good seal with the airbox. When you say Silicon grease I think of RTV or gasket sealant don't use that, use regular grease so you can get the filter out. I don't think it really needs it but it wouldn't hurt.
Old Jul 20, 2005 | 02:19 PM
scootergptx's Avatar
Supersock
Hired Gun!
You can pick up a small tube of white grease at the auto parts store. Like EAB said, not necessary, but if you go through a lot of water, it's not a bad idea.
Old Jul 20, 2005 | 05:21 PM
Perky's Avatar
Silicone grease isnt a atv sealer which bonds..it"s a grease which conditions rubber and is any grease, but it isnt petroleum based..petroleum based grease deteriates
rubber which in turn ruins your filter seal....thats why K_N suggest you use white lithium whichwould be my top choice or synthetic grease....I had the silicone grease on hand so I used that.....silicone grease is used on elecrical connections to gaurd against moisture and such..
Old Jul 20, 2005 | 05:35 PM
Cool, Thanks for the Info Perky I didn't know there were silicon based greases. I guess when I think of grease I automatically think of the petroleum based variety. I like to learn new things!
shimanok2
Jan 29, 2016 07:37 PM
bombrider04
Apr 5, 2007 03:21 PM
bombrider04
Apr 5, 2007 10:56 AM
bombrider04
Mar 12, 2007 10:08 PM
Voodoo52
Mar 11, 2004 12:12 PM
