Go easy on those 250s.......yeah right! go ahead and blow em up
I just got a new rear shock and my HPD pipe put on and i was riding arround not more than an hour and i blew the motor. I havent had a chance to look inside yet. The bore was new last summer. The only thing i can think of is that it got way too hot cause my jetting was lean. But the last time this happend it was totally stock, and the jetting was perfect, and the bore had about 400hrs on it. Im getting it bored and a new piston and rod installed. Possibly some porting and getting the head milled. If i get the head milled will i need to run a higher octane? (the highest sold arround here is 91)
Same thing here, mine was an 02 xplorer. Completely stock, started to bog, then died. Couldnt pull the pull start, completely frozen. Pulled the plug, it was pitted, grey, and burned. No idea what caused it.
well heres the scarry part i can pull the rope w/ one arm! Im gonna guess the rod is totally disconnected from the piston or the crank im not sure which
[img]i/expressions/face-icon-small-frown.gif[/img]
I had the dealer fix mine, I don't like messing with the internals of engines, if they screw anything up they can deal with it. It was 400 for the whole repair. But now it sounds really high pitched and pingy. Maybe the new engine still on break-in?
you think ill need to re-bore if the piston has a hole? ///////// mine was realy high pitched and pinged alot till i got it broke in but its still a lil more high pitched than it used to be
More than likely but make sure first. Take the cylinder down to the dealer and have him check the bore for trueness and go from there. I wouldn't tell him what happened just see if it needs to go to the next bore. If it was a real bad meltdown then it will probably be pretty obvious what happened.
thanks for the advise by the way thats one helluva scrambler u have there duneaholic! ive seen some footage and you were spankin those yama 450s pretty bad!
exmotocrosser
Sep 13, 2019 06:12 AM
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
