A trick to getting the front sprocket off?
Old Jul 20, 2005 | 01:14 AM
trick25's Avatar
Default A trick to getting the front sprocket off?
ok guys im new to the sport quad market so be gentle. im trying to replace the sprockets and chain on a 96 warrior i bought about a month ago. they are severly worn and streached.
The back scrocket went off easy but im having fits with the front.
i took off the nut and the lock washer. but the sprocket wont come off. do i have to use some sort of puller or what?
Thanks for any help
Chris
Old Jul 20, 2005 | 02:47 AM
RaptorRookie's Avatar
Try using a flat screw driver, or something similar. and gently pry it off. Start one one side and just work your way around. You might also try spraying some WD-40 on it, that might help a bit.
-Brandon
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
