warrior sticky throttle?
Old Jul 20, 2005 | 01:48 PM
Yamahakid1's Avatar
Default warrior sticky throttle?
bikes been sittin in the garage for a few weeks. i start it up starts first try. the nwhen i get to about 3/4 hrottle it starts cutting out and then if i pin the throttle down it sticks and then slowly relaeses. i have cleaned out the carb except i cant get to the float bowl becuase the screws are stripped. anyone know how to get stripped screws off. also what is my problem?
Old Jul 20, 2005 | 03:54 PM
Pelphrey's Avatar
Check your parking brake if you haven't done so already.
Old Jul 20, 2005 | 06:04 PM
fullthrottlez400's Avatar
To get the screws out get a dremel and cut a straight groove in the screw head with a thin cutting wheel and you should be able to use a flat head screwdriver to take them out. The throttle sticking problem I'm not sure about, but you could check your throttle cable if the throttle is releasing slowly, it might be time for a new cable
Old Jul 23, 2005 | 07:36 PM
Yamahakid1's Avatar
no its not the parking brake i checked it looks like its the throotle cable maybe i need a new one? but like i said it sticks when u [pushi t all the way down then it will slowly release bak into the rest positon
Old Jul 23, 2005 | 07:59 PM
DeathShadow's Avatar
You can also use some needle nose - grip the screws real hard and turn them.
Old Aug 7, 2005 | 03:13 AM
TecateKtx250lover's Avatar
VICE GRIPS BABY!
Old Aug 7, 2005 | 01:24 PM
UltimateAussie's Avatar
impact screwdriver. i got a craftsman one for 24 bucks from sears best money ive spent in a while even if the screw is hinting that it might striip you just hit it with the impact driver and it pops it loose
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
fordfaithful21
Dec 7, 2015 05:52 PM
craacker
Sep 9, 2015 04:32 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
