250 CC REED VALVES
Old Jul 20, 2005 | 11:44 PM
7haj3's Avatar
Default 250 CC REED VALVES
I saw on eBay an ATV dealer advertised a reed valve for a 87 thru 93 250 cc trail boss 4x4. I have a 88 250cc trail boss 4x4, and as far as I can tell it has no reed valve. I just replaced the carb and I looked for the reed valve and I could not find one. Is it supposed to have a reed valve? You may remember a couple months back I posted numerous times trying to get a carb I bought on ebay to work right and it never did. I finally found out it was a 28mm carb and not a 30mm that I needed. It was misrepresented and the guy refunded my money. I bought a 30mm and it runs like new. I just wondered about the reed valve, from what I understand about 2 strokes some have a 3rd port instead of a reed valve. Am I right?
Old Jul 21, 2005 | 02:02 PM
fishslab's Avatar
Polaris 250s are considered piston port motors. The piston blocks the intake and exhaust as needed for that particular stroke. No reeds needed. If you were to radically change the port timing or the stroke you could throw off the port openings and closings. A couple companies offer a reed conversion for the 250, I would assume they have changed the porting or stroke to make it necissary.
Old Jul 21, 2005 | 05:56 PM
7haj3's Avatar
Thanks for the reply. Thats what I thought, I have found that some of the products on eBay are misrepresented so they will bring a higher bid.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
