Any help on making my 400EX faster?
I have a 400EX, and I plan on doing some more mods on it fairly soon. What would you all suggest? I would like to make it faster on the local MX track. Please help if you can. Thanks in advance for help.
Will that cam help me out very much? Will it still have plenty of low-end and acceleration as well as mid-range and top if I add the cam and the high-compression piston? Do you know about the price of the cam?
One thing is if you want to race AMA sanctioned 250 2 stroke you might want to wait before you purchase a piston. They may allow 440s to run where now they only let 416's in the 250 2 stroke.
I have Curtis working on my motor right now and hopefully the end result will be a 440 National. His 440 uses a sleeve that is the same thickness the entire length so you have to have your cases machined to allow for the sleeve. Also it allows you to use a larger bore size I believe you can go to 465 with his sleeve.
I have his X-4 exhaust right now it is really sweet. You can find info about sparks on his website.
Adam Smith
99 400EX
Adam Smith
99 400EX
