Cooling Fans for Sportsman 500 - 700 twin
Old Jul 23, 2005 | 01:36 AM
SuperB24's Avatar
Default Cooling Fans for 2002 700 twin
My cooling fan started making alot of noise so I removed it and found the front bearing was out, I tried all day to find the exact model number fan and could not, so I called Spal ( The maker of our fans) and they told to replace the motor with a 30101500 (or 500 series from other people) because those fans are special order for polaris only. get this fan (it's the AP50 in the model number you need in the 500 series,) and just remove the motor and put it on your fan blade and shroud, worked like new one from Polaris, and has same model number too. Just thought I would save you from spending $219.00 when you only need to spend $85.00. I can help you with the vender if need be.
Old Jul 23, 2005 | 02:28 AM
Treacherous's Avatar
Awesome money saver if in need of a cooling fan motor!
Thanks!
Old Jul 25, 2005 | 06:00 PM
SuperB24's Avatar
Default Cooling Fans for Sportsman 500 - 700 twin
This is an easy fix for anyone, will save you lots of $$$ for GAS !!!
Old Jul 26, 2005 | 10:35 PM
jace0311's Avatar
will that part# 30101500 fit the 500ho. i emailed spal anthe said i would have to use the oem they did not have a pelacement. where did you get the aftermarket fan
Old Jul 26, 2005 | 10:54 PM
SuperB24's Avatar
What I did was ordered the fan that Spal told me had the same Model number "Motor" (30100500) as the 500 - 700's, When I recieved it all I did was put my blade and shroud on it and I had a brand new fan again, if your blade or shroud are broken, I think it will still work just fine, except the mounting holes are different that attach the shroud to the radiator, but if all you need is the motor, your in great luck for few $$$. good luck, if you need some more help, please let me know. p.s this is so easy anyone can change it.. 4 screws, one small clip, and ta da !!!!
Old Aug 9, 2005 | 11:34 AM
ZigZilla's Avatar
SuperB24, Thanks for the info......can you give me the contact info to purchase this fam assembly??
Thanks
Old Aug 9, 2005 | 06:14 PM
SuperB24's Avatar
Contact the Fanman at the-fan-man@the-fan-man.com 1-866-435-6477 and order the 500 series fan (#30100500 pull fan) and he'll send it with free shipping. pull the fan blade then swap the motor to your shroud, reinstall the fan blade,"I used the one that came with fan because it pulls more air" . you will have to swap the electric connection ends as the right ones only come on the $219.00 fan from polaris, yikes !!!, but its no big deal. use shrink rap for wiring if you have it or at silicone the splice to keep it water tight. good luck, let me know if can help. SuperB24
Old Oct 9, 2005 | 08:43 AM
OldGrayHair's Avatar
Is there some trick to getting the fan off the motor? I have pulled the clip and removed the four screws but the fan blade will not come off.
Old Oct 9, 2005 | 10:01 AM
NascarFan's Avatar
Great info. I ordered one this morning. Mine has been "singing" for a year or two. Had to spin-start it once. Glad to finally find a replacement part. Thanks.
Old Oct 9, 2005 | 10:27 AM
encorebilly's Avatar
My 05 500 ho has a different fan than my 05 700 efi.The 700 is the same as the 800.
