** 88 250R stock cylinder bore limit? **
Old Oct 16, 2000 | 12:13 AM
Adams44's Avatar
How far can you bore a 250R cylinder?
A circlip came out this weekend and the wrist pin made two nice DEEP gouges in the cylinder wall.
Thanks for the info!
Old Oct 16, 2000 | 12:34 AM
mindcrime's Avatar
On the Honda post I answered you already, but here it is again. Since you included the year of your quad, the correct answer is 68mm. Did I BECOME A MILLIONAIRE?!?
Old Oct 16, 2000 | 07:12 AM
LT250R_86's Avatar
I'm at 68.75mm and have 2 "safe" bores left, beyond that your pushing it. So a 88 cylinder can safely be bored to 69.25mm. Which is a tad over 270cc.
Old Oct 16, 2000 | 03:19 PM
mindcrime's Avatar
LT250R_86, what piston are you running in your overbored 88 250R? I have not seen a piston(Pro-X or Wiseco) listed in catalogs for '87-'89(long rod) that goes over 68mm. Are you running the '86(short rod) piston with a spacer plate? The '86 piston IS LISTED up to 69mm. Help inform me please.
Old Oct 16, 2000 | 06:18 PM
rsss396's Avatar
mindcrime'
you will have to run a 5mm spacer plate to run the larger "86" style pistons that Pro-X and Weisco makes.68mm is the largest long rod style.
Old Oct 16, 2000 | 07:01 PM
LT250R_86's Avatar
Yup, I run a 86 ProX piston with a 5mm spacer plate. Its a MacDizzy 270 Kit. Rick did the motor.
Old Oct 17, 2000 | 01:54 AM
mindcrime's Avatar
YUP, that's what I thought! I first learned of the ole 5mm spacer trick on my old CT310(295!!!)kit with its '86 style piston. Thanks for CLARIFYING for the under-informed! Later.
Old Oct 17, 2000 | 02:01 PM
steve250R's Avatar
Is a '86 cylinder the same as a '87-'89 cylinder or are they different? What i want to know is can you run a '86 cylinder on a '87-'89 bottom end with a '87-'89 piston. or run a spacer plate on that set up with a '86 piston.
Old Oct 17, 2000 | 02:23 PM
mindcrime's Avatar
The cylinders ARE DIFFERENT on the '86 vs the '87-'89. The main difference being two webs in the intake to help keep the rings from expanding as much AND improvements in the exhaust porting were incorporated into the later years cylinders. You can use the '86 cylinder on a '87-'89 lower. If you use the '86 piston you will have to run the 5mm spacer plate---you don't with the '87-'89 piston. The reason for this if you didn't already know was in the '87 and up motors, the ROD LENGTH was increased 5mm and wrist pin hole was moved up 5mm. This is why the later models are referred to LONG ROD motors. Honda did all these improvements to improve overall reliability. The short rod motors are said to be more PEAKY(read more HP) and many prefer them in most racing applications other than XC racing. The long rod motors had a smoother and longer "PULL" in their powerbands and that is why many prefer them in the woods(read more torque). Hope this was helpful!
Old Oct 21, 2000 | 02:24 PM
Jason454's Avatar
I had an atc 250r and I`m pretty sure it was borable to .140 over. Wiseco piston.
Ramman1
Jun 16, 2016 09:07 PM
Huntingdeer
Aug 23, 2015 12:06 AM
manuelrivera
Aug 8, 2015 04:34 PM
CRamshaw777
Jul 18, 2015 05:46 PM
