sportsman 26 inch tires
Old Jul 26, 2005 | 01:16 AM
traction's Avatar
Default sportsman 26 inch tires
Did polaris gear down their sportsman models when they changed to the 26" pxts from the 25" tires? Is there a noticeable difference in power when putting the taller treads on an older atv?
Old Jul 26, 2005 | 01:39 AM
elkbow's Avatar
I would think that the clutching changed. I'm running 27" tires on my 2005 700 EFI and they work great. I've had it up to 68 mph on a slight downhill with the 26" tires, can't tell on the 27's really how fast I'm going as the speedo is alittle off, had it up to 60 with the 27's, but not sure how fast that is going....
Old Jul 26, 2005 | 07:00 AM
polarisbear500's Avatar
i have the 99 model and i run the 26" mudlights with the c-series rims and you can notice a difference some, but not that much, i mean if you are trying to do top speed, then yes the difference is somewhat noticeable, but the loss of a few MPH on top end is definantly worth it for the grip and traction you get. My opinion-PB500
Old Jul 26, 2005 | 01:57 PM
jimmypsp700's Avatar
I have the 26 " on my 02 700 and you might notice it a little in acceleration.
Jim
Old Jul 26, 2005 | 03:10 PM
Halffast's Avatar
Elkbow,
Assuming the speedo is correct with the 26" tires (That's a big assumption) then you are traveling 27 mph for each 26 mph indicated. So if you're showing 60, then you're really going 62.3. HTH.
Old Jul 26, 2005 | 03:44 PM
Thor's Avatar
If you do experience a power loss the best and least expensive cure is the installation of the White spring in the primary clutch.
Old Jul 27, 2005 | 12:30 AM
traction's Avatar
Thanks a bunch for the many replies, helps me a bunch.
Jmuddin284
Jan 19, 2026 07:16 AM
Shifts
14
Jul 13, 2015 08:41 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
coolguy420
Jul 10, 2015 01:17 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
