Dial-a-jet Good Or Bad?
Old Jul 26, 2005 | 09:27 PM
DanMan83's Avatar
Default Dial-a-jet Good Or Bad?
Has anyone had any experience with the dial-a-jet kit from HotSeat? If so, how was it? And does that mean you don't have to mess around with a whole bunch of different jets to get your quad tuned how you like it?
Old Jul 26, 2005 | 10:07 PM
SPORTSMAN70003's Avatar
I had one and I couldn't get it to work right.
Old Jul 27, 2005 | 01:04 AM
scramblerXrated's Avatar
i recently installed one on my 500 scrambler. it was way easy to install and even easier to adjust. i really like it. runs very strong. has a much better pull in mid to top end ranges.
X
Old Jul 27, 2005 | 01:18 AM
oldsmoboat's Avatar
Has anyone leaned out their machine too much and burned it up? How do you be sure that you don't go too lean? O2 sensor?
Old Jul 27, 2005 | 09:21 AM
gotta check your sparkplug. its the oly way to be sure.
X
Old Jul 27, 2005 | 10:42 AM
Halffast's Avatar
X
I thought nuking them from orbit was the only way to be sure!
Sorry, couldn't resist.
David
Old Jul 27, 2005 | 11:23 PM
firemedic5586's Avatar
Sportsman70003 and myself are both running O2 sensors (different models) sure is alot easier then reading the plugs. I'm very glad that I spend the $$ for mine. I think Sportsman would say the same.
Old Jul 27, 2005 | 11:28 PM
Yea it was worth the money for the 02 sensor. Did you get your Dynojet tuned in?
Old Jul 27, 2005 | 11:34 PM
Sorry I havent given you a ring, way too busy to do anything with the machine in the past couple weeks.
The whole shot looks good...Dropped down to the 170 main jet. Front end will come right up, and try pulling your arms off doing it; and thats in high. Going to play a bit tomarrow and see if I need to adjust the needle at all. The air screw seems right on at 1 1/2 turns out.
Nondem
Feb 22, 2020 12:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
