YEARLY/BI-ANNUAL MAINTENANCE
Old Jul 26, 2005 | 11:19 PM
polarisbear500's Avatar
Default YEARLY/BI-ANNUAL MAINTENANCE
i was needing a list of things to check/change to keep my atv running smooth and out of the shop...things such as the ones below and when to do the things below:
oil changes
air filter re-oiling(UNI)
front gearcase
rear gearcase
transmission
radiator fluid
hub fluid
spark plug
plug wire
greasing the zerks
and anything else you all do and when the times you do it...thanks ALL-PB500
Old Jul 26, 2005 | 11:28 PM
lslubecki's Avatar
Brake pads especially rears, greasing all the zerks, chain tension if applicable, fill fuel tank fluid.
Steve Lubecki
Old Jul 26, 2005 | 11:30 PM
thanks, but i was needing not only WHAT to do but WHEN to do,like every month, every ride, etc...thanks
Old Jul 27, 2005 | 12:19 AM
Venom's Avatar
Go to polaris web site and under buying tools look for brochures,on the lower left you will see down load a manual , click on this then fill in your info. it has all the maintenance info you need.
Old Jul 27, 2005 | 07:24 AM
i went there but i can't download on the comp. at work. i was hoping someone on here would tell me there routine maintenance they do to their quads to keep them going. thanks
dannytas
Sep 26, 2017 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
