Tb 250 overheating?
Old Jul 27, 2005 | 01:33 PM
tblazer's Avatar
Default Tb 250 overheating?
Has anybody had trouble with their trailblazer 250 overheating with headmilling and/or other mods. Mine seemed to be running hot so i replaced it with the stock carb and it helped a bit.
Old Jul 27, 2005 | 03:18 PM
ATVnRocks's Avatar
Try to add more fuel in your jetting, sounds lean.
Old Jul 27, 2005 | 10:10 PM
tblazer's Avatar
With stock carb i am running a 150 jet. Do i need to go bigger.
Old Jul 28, 2005 | 11:53 AM
ATVnRocks's Avatar
I'd probably go big enough to make it run crappy, then back out till it runs sweet, pilot, needle, & main all should be rejetted for what you've done.
Old Jul 28, 2005 | 12:40 PM
mudmaster250's Avatar
with a 150 main wtih a pipe and porting your lucky u didnt stick a piston or a ring yet. im runnin a rcr pipe with azbadboyz porting and a 180 main in the stock carb. this is a with a twinair filter with no airbox snorkel. i would go up to a 190 and see how it runs and back off a size until the bog or "gurgle" clears itself up. what is your needle set at?
Old Jul 28, 2005 | 12:57 PM
tblazer's Avatar
I believe i went up one notch from stock position for the needle. WHenever i stop hold in the brake and then gun it holding the brake it always bogs out on me. What should be the correct needle settings if i had gone to a 180 or 190 main jet.
Old Jul 28, 2005 | 01:01 PM
theres no way for me to give u an exact needle spec but i would go to one position below stock(richer) and go leaner till it cleans itself up just like your gonna do with the main. so do that and put in a 190 and go down in size untill it clears up and you should be good.
Old Jul 28, 2005 | 01:05 PM
tblazer's Avatar
By the way mudmaster, how does your trailblazer fair against scramblers. Mine stays with a 500 on bottom and then i get wasted until i hit top end and then i can hang with him descent.
Old Jul 28, 2005 | 01:08 PM
ive never raced a scrambler but against a 350 warrior its right with it untill about 4th or 5th gear then he pulls away.
Old Jul 28, 2005 | 01:12 PM
tblazer's Avatar
Thanx for all the help. I probably sound like an idiot when it comes to atvs. My motorhead skills are in the snowmobile department.
