800 pull start
Old Jul 27, 2005 | 10:21 PM
spyder6's Avatar
Default 800 pull start
ok, i know that even attempts at pull starting a 700 is going to be super bitch +1. so, considering the 800 shares the same crankcase as the 700, im considering mounting a pull start. i know that since my quad is EFI, there might not be enough power to get the EFI jump started, however, apparently, the 06' 500 EFI, has a pull start to it, makeing it pheasable some how.
since the compression of the 800 is only slightly increased than that to the 700, the pull shouldent be overly different, other than ripping your arm off. what do you guys think of my idea, also, how much does the 700 MV pull cost, and do i just take off the crank basket on the right hand side and mount this one? im also guessing since im screwing with the crank that im going to have to drain my oil?
thanks all
Old Jul 27, 2005 | 11:34 PM
SPORTSMAN70003's Avatar
I heard of a guy that was going to install one on his 700 over at the atvwild fourm. Also you won't have to drain the oil to put it on.
Old Jul 27, 2005 | 11:38 PM
spyder6's Avatar
do you know if it was a EFI 700 or not?
Old Jul 27, 2005 | 11:42 PM
I'm not for sure its been a while since it was posted but I think it was a carb. I will look to see if I can find the post.
Old Jul 27, 2005 | 11:44 PM
spyder6's Avatar
thanks
Old Jul 27, 2005 | 11:50 PM
It was a 02 700 carb model. I'm not for sure he had it put on or not. I will post a reply and see.
Old Jul 28, 2005 | 12:03 AM
spyder6's Avatar
its ok, thanks, im gonna stop by Waynes tommarow and ask Jermey what he thinks, jeeze i have him on a speed dial on my cell phone, might as well just call him
Old Jul 28, 2005 | 01:07 AM
Storj's Avatar
Dont know if this applies or if there diffrent when it comes to efi but alot of snowmobiles are efi and pull start and are in some cases more than 800cc also its not that hard to pull that thing over i pull a 700 over all the time its all in your strategy[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 28, 2005 | 01:09 AM
spyder6's Avatar
i suppose it dosnt matter, i think i'll order one and slap it on
Old Jul 28, 2005 | 02:37 AM
mtpockets's Avatar
please post on how things work out.
thanks,
~MT
