Alcohol EFI Fuel Pump
Old Jul 29, 2005 | 01:21 AM
ScoobyDFW's Avatar
Default Alcohol EFI Fuel Pump
For those who have been running the KMS EFI fuel pump for a while now on alcohol, have you had a pump go bad? Every pump I try doesn't last very long.
Old Jul 29, 2005 | 01:25 AM
5X's Avatar
5X
Just wondering, Have you been running top lube with your alky? I know It works great on race cars. Redline top lube is good.
Old Jul 29, 2005 | 01:27 AM
ScoobyDFW's Avatar
yes I use toplube. Klotz, and I put in 3 times what it recommends.
Old Jul 29, 2005 | 01:58 AM
Sandaholic's Avatar
Scooby, good to see you still alive! haven't seen you post around here in a while
I had a pump fail on my efi but I am not running alcohol. Kelly at KMS took care of it right away. He said things that cause fuel pumps to go bad are heat, running dry on fuel (cavitation and more heat), and alcohol. He has not found one pump that will put up to the corrosiveness of alcohol. Only thing the prolongs the life is flushing the system with fuel.
Old Jul 29, 2005 | 09:04 AM
Majorecho's Avatar
I never had an issues with my fuel pump and I never flushed the system either, it was still running strong after 18 months of use. It was the first generation of fuel pumps that Kelly used, I believe it came off of the LS1 motor, I didn't have it mounted to the frame it was just suspented by the fuel lines in the air.
PrairieDog126
Sep 12, 2015 06:53 PM
essonlaker
Sep 10, 2015 01:12 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
