Scrambler 400 "cheapest mod's"???
Old Jul 31, 2005 | 02:45 PM
bongload's Avatar
Default Scrambler 400 "cheapest mod's"???
I have a 1998 Scrambler 400 4x4 [2-stroke] I was wondering what would be the easiest & cheapest way to make the machine run alittle stronger than stock. {jetting etc...} I do not want to give up any reliability.
Thanks for any help!!
Old Jul 31, 2005 | 02:55 PM
fishslab's Avatar
How cheap are we talking? A pipe and clutch give you the best bang for your money. You can put a stiffer primary spring for a little extra punch. That's about $20.
Old Jul 31, 2005 | 02:57 PM
duneaholic's Avatar
RcR stage one. 325.00 bucks shipped. Includes pipe/silencer,jets, filter,and airbox mods. Can't beat a deal like that. That also includes the best customer service in the buisness.
Old Jul 31, 2005 | 04:59 PM
bongload's Avatar
OK...Thanks.
I allso heard that the stock piston will probly take the cylinder skirt with it when it goes. Should I rebuild it know with a wiseco or wait untill it starts to run low on compression?? allso when it's apart does a very mild port job work good on this motor with stock pipe?? What about shaving the head??
Thanks!
PS: Does an after market head pipe really help this motor enough to make a noticable difference???
Old Jul 31, 2005 | 09:35 PM
Fastestdad's Avatar
Yes the pipes make a huge difference.
Old Jul 31, 2005 | 11:14 PM
duneaholic's Avatar
Originally posted by: bongload
OK...Thanks.
Thanks!
Yeah I would change out to a Wiseco if you are gonna redo the top end. The stockers do tend to break the skirt. I wasn't sure how cheap of mods or radical you were wanting. The stock pipe doesn't respond to porting all that well. A good trail port with a good pipe will give you around 15-20 hp increase. Shaving the head will bump up the compression and help with overall power. You can shave the head .020 and still run 92 octane fuel.
Old Aug 1, 2005 | 12:00 AM
oghma's Avatar
RCR stage one is the best deal if you want to mod a decent amount. For a cheap mod I would do a clamp on filter and toss the airbox, then a new pipe, after that rejet your carb and enjoy that alone will make a noticeable difference.
Old Aug 1, 2005 | 10:33 AM
scramblered's Avatar
well i'm assuming you were running a little rich with stock calibrations,
put a k&n air filter and that is easy and cheap with still reliability.
a set of reeds can help you out to search what you looking for...
Old Aug 1, 2005 | 10:40 AM
conig's Avatar
replace the piston first. I didn;t and its alot more expensive after the skirt gets ground up in your crank, fortunatly my cases didn't get a hole in them or anything. when its apart have the head shaved 0.020 it makes a good difference.
K&N clamp in is good as well but I see you are a 4X4 so keep in mind you will loose some water protection.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
